Ga door naar hoofdinhoud
Samsung Galaxy Note 3 Rear Facing Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove the rear case: stap 1, afbeelding 1 van 1
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: stap 2, afbeelding 1 van 2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: stap 2, afbeelding 2 van 2
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: stap 3, afbeelding 1 van 2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: stap 3, afbeelding 2 van 2
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Galaxy Note 3 Rear Facing Camera Replacement, S Pen: stap 4, afbeelding 1 van 1
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unscrew Back Chassis: stap 5, afbeelding 1 van 1
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Back Chassis: stap 6, afbeelding 1 van 1
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: stap 7, afbeelding 1 van 2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: stap 7, afbeelding 2 van 2
    • Remove the single screw beside headphone jack.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: stap 8, afbeelding 1 van 2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
    Vraag FixBot
    Voeg opmerking toe
  9. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Motherboard Removal: stap 9, afbeelding 1 van 1
    • Pull up on the motherboard with tweezers.
    Vraag FixBot
    Voeg opmerking toe
  10. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unclipping the Camera: stap 10, afbeelding 1 van 1
    • Unclip the camera connecting cable using the plastic opening tool from the motherboard
    • Remove loose camera from base
    Vraag FixBot
    Voeg opmerking toe
Conclusie
37 andere personen hebben deze handleiding voltooid.
Brittany Gail
8.581 Reputatie
8 handleidingen geschreven
USF Tampa, Team 2-2, Blackwell Fall 2014 Lid van USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
4 Leden
32 handleidingen geschreven
3Gids Commentaar
Awesome, phone disassembly and fingernail painting at same time :) Thanks for your time to post this!
Chris G - Antwoord Deel
Hi
Thanks for the nice instructions
Do you know if I can use a Note 4 camera (or any better!) for my Note 3?
Are they different in connections?
Thanks
hameidfehri - Antwoord Deel
I shall be very thankfull for this act of kindness
Malik wajdan ali - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 52
Altijd: 14,240
