Ga door naar hoofdinhoud
Samsung Galaxy Note 10.1 microSD Port Replacement
Wat je nodig hebt
  1. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Top Piece: stap 1, afbeelding 1 van 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Top Piece: stap 1, afbeelding 2 van 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Top Piece: stap 1, afbeelding 3 van 3
    • This is the back of the device and where you willl begin to take it apart
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Back Cover: stap 2, afbeelding 1 van 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Back Cover: stap 2, afbeelding 2 van 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Back Cover: stap 2, afbeelding 3 van 3
    • Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the microSD Port: stap 3, afbeelding 1 van 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the microSD Port: stap 3, afbeelding 2 van 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the microSD Port: stap 3, afbeelding 3 van 3
    • Unscrew the two 2 mm screws indicated by the red circles with the #00 Philips Screwdriver.
    • Starting with the black motherboard connector, remove the module indicated by the red box in the second picture.
    • Replace the microSD port with a similar model.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Tyler Salomone
1.020 Reputatie
3 handleidingen geschreven
USF Tampa, Team 3-7, Brown Fall 2014 Lid van USF Tampa, Team 3-7, Brown Fall 2014
USFT-BROWN-F14S3G7
3 Leden
9 handleidingen geschreven
2 opmerkingen
Be sure to include screw lengths to the nearest mm on all guides.
Dan Brown - Antwoord
In this guide, you missed a step on removing the battery.
John Peterson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 3,888
