Wat je nodig hebt
This is the back of the device and where you willl begin to take it apart
It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
Use the plastic opening tools to pry along the indicated box.
Lift up the silver piece to reveal the rest of the back cover.
Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
Remove the back cover.
Carefully remove all of the ribbons that connect over the battery from the locations indicated by the yellow circles.
Remove all of the 3 mm screws indicated by a red circle with the #00 Philips screwdriver.
Disconnect the battery from the location indicated by a yellow circle
Now you may remove the battery.
From the first photo:
Remove all the components marked by yellow circles
Unscrew all the 2 and 3 mm screws marked by the red circles with the #00 Philips screwdriver.
From the second photo:
Starting with the motherboard connectors, remove all the components marked in red.
Once you have removed all the components connected to the motherboard, gently lift up on the area surrounding the green box and remove your motherboard.
Apply pressure to the locations boxed in red to remove the loudspeaker modules.
These are your loudspeaker modules, replace with the new parts
7 andere personen hebben deze handleiding voltooid.
2 opmerkingen
In Step 7, mention that you should use the plastic tools to pop the speakers out of the device.
