Ga door naar hoofdinhoud
Samsung Galaxy Note 10.1 Rear Facing Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Top Piece: stap 1, afbeelding 1 van 3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Top Piece: stap 1, afbeelding 2 van 3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Top Piece: stap 1, afbeelding 3 van 3
    • This is the back of the device and where you willl begin to take it apart
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Back Cover: stap 2, afbeelding 1 van 3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Back Cover: stap 2, afbeelding 2 van 3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Back Cover: stap 2, afbeelding 3 van 3
    • Unscrew the three screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Camera: stap 3, afbeelding 1 van 3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Camera: stap 3, afbeelding 2 van 3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Camera: stap 3, afbeelding 3 van 3
    • Start by lifting the white connector to remove the part indicated by the red polygon.
    • Gently pry along the camera hub to lift it out of its location.
    • This is your camera. Replace it with the new part.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Bryan Fernandez
241 Reputatie
2 handleidingen geschreven
USF Tampa, Team 3-7, Brown Fall 2014 Lid van USF Tampa, Team 3-7, Brown Fall 2014
USFT-BROWN-F14S3G7
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 2,201
