Inleiding
This guide will teach how to replace the motherboard in your Samsung Galaxy 10.1 2014 edition.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Spudger$2.99
Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
Remove the three 3mm screws on the top right side of the device with the Phillips PH000 screw head.
Remove the one 3mm screw on the top left side of the device with the same method.
Remove the gray rubber piece.
Use a spudger or fingernail to disconnect the blue antenna cable from the motherboard.
Remove the right speaker unit.
Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
Gereedschap gebruikt in deze stap:Phillips #000 Screwdriver$5.49
Remove the six 3mm screws around the battery with the Phillips PH000 screwdriver.
Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
Use the black nylon spudger to gently lift the motherboard away from the frame.
Remove the motherboard.
Hola. Muy bien tu blog.
No encuentro la barrita delgada negra se me ha roto. Como hago
7 andere personen hebben deze handleiding voltooid.
5 opmerkingen
hi. i have one of this tablets and i need a ic guide for it. something like this link :
Samsung Galaxy Note 10.1 Teardown
this like is for galaxy note 10.1 2012 but i need it for 2014 (SM-P601).
any documents or files to help me recognize which Chip do what ?
Can I use this motherboard with Galaxy note 10.1 GT-N8000 ? Plz reply fast
Can I use this motherboard with Galaxy Note 10.1 GT-N8000 ? Plz reply fast
miss 1 screw when removing the motherboard on the center right side
Remove stylus before you remove. There’s a nubbin on the main board that may dislodge it stylus is in place. it is easily reinserted, but easy hassle to avoid.
Matt - Antwoord
It’s worth mentioning that there is a part of the device casing, accessible from the back, that can be removed but has very fragile retaining clips. Although the picture does show that the prying tool is lifting the screen, it is hard to see. You will not be able to access the charge port by removing a portion of the casing. You must remove the case from the screen side.
Eden Mugg - Antwoord
Be careful!!!
the first picture of this first step and the instructions are misleading. What you need to remove is the back cover of the tablet. Use the opening tool along the edges of the back cover, NOT on the screen as the picture and the instructions say.
rene carmona - Antwoord
Its not misleading. You need to remove from the front as removing from the back you will tear the grey clipping from the glued back piece. You will not be able to replace the charge port from removing just the back either as you should be doing both.
Bradley Carr -
I agree this first step should be revised and include a warning.
My battery was swollen and the screen was separating from the case (big gap along edge).
Purchased new battery. Have spudger. Have done phone battery replacements before without issue.
I tried to do the separation but apparently was between the screen assembly and the back electronics rather than separating the entire electronics from the back casing.
The screen glass “exploded”…I’ll be finding glass particles in my office for the next few years I think. In addition, not realizing why things weren’t working I figured I would have to replace the screen anyway and continued on only to discover that a bunch of ribbon cables were destroyed during separation.
Given this process is listed as “EASY” there really should be some clear warnings about making sure the spudger doesn’t end up between the screen assembly and back electonics but rather ends up between the back case. The angle of the spudger in the photo doesn’t make this obvious.
What a waste.
mattp - Antwoord
