Ga door naar hoofdinhoud
Samsung Galaxy Note 10.1 2014 Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy Note 10.1 2014 Battery Replacement, Case: stap 1, afbeelding 1 van 2 Samsung Galaxy Note 10.1 2014 Battery Replacement, Case: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Spudger
    $2.99
    • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
    • If possible, consider using the black nylon spudger for a gentler separation.
    Vraag FixBot
  2. Samsung Galaxy Note 10.1 2014 Battery Replacement, Battery: stap 2, afbeelding 1 van 1
    • Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
    • Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
    Vraag FixBot
  3. Samsung Galaxy Note 10.1 2014 Battery Replacement: stap 3, afbeelding 1 van 1
    Phillips #000 Screwdriver
    $5.49
    Vraag FixBot
  4. Samsung Galaxy Note 10.1 2014 Battery Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy Note 10.1 2014 Battery Replacement: stap 4, afbeelding 2 van 2
    Spudger
    $2.99
    • Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
    • Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
    Vraag FixBot
Conclusie
27 andere personen hebben deze handleiding voltooid.
Joseph Rasico
2.200 Reputatie
6 handleidingen geschreven
USF Tampa, Team S1-G6, Leahy Spring 2017 Lid van USF Tampa, Team S1-G6, Leahy Spring 2017
USFT-LEAHY-S17S1G6
3 Leden
7 handleidingen geschreven
5Gids Commentaar
Step 1 you have to show the back cover to remove. Showing the front side is confusing.
After step 4 there should be a step 5 to show how to disconnect the white connector with the colored wires: it took time to discover that you have to lift the 2 side clips, and not to pull…
prisca - Antwoord Deel
Just followed your instructions. Used a online kit with a guitar pick-like spudger. Had to wrestle with it slightly, but everything worked out perfectly to your instructions.
Matt - Antwoord Deel
You said it was like a guitar pick so I used a guitar pick. Worked pretty well. Guitar pick is bent up but they are cheap.
Stephen Nichols - Antwoord Deel
Followed the instructions. Worked nearly perfectly. The last step is a bit tricky. Just look at the new battery to understand the system.
Eramur - Antwoord Deel
Something I won’t be doing again. It was very annoying to do and nerve racking to complete. Was a pain to snap back together.
Bradley Carr - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 113
Altijd: 23,846
