Ga door naar hoofdinhoud
Inleiding
Use this guide to replace the motherboard in your Samsung Galaxy Nexus
  1. You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
    • You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
  2. Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot. Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot. Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
    • Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
  3. Insert your finger into the divot of the  battery and pull the battery towards yourself to remove. This is when a new battery will be inserted. This is when a new battery will be inserted.
    • Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
    • This is when a new battery will be inserted.
  4. Remove 4.4 mm screws using a PH # 000 as indicated on the picture. Remove 4.4 mm screws using a PH # 000 as indicated on the picture. Remove 4.4 mm screws using a PH # 000 as indicated on the picture.
    • Remove 4.4 mm screws using a PH # 000 as indicated on the picture.
  5. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Nu winkelen
    iPhone X Fix Kits
    Nu winkelen
  6. After removing the screws be sure to turn the phone right side up. Insert your plastic opening tool between the screen and the outer case. Move the opening tool around the phone without removing it from in between the screen and the shell of the phone. Pop the screen out of the outer shell. Be cautious not to damage the control board or the screen.
    • After removing the screws be sure to turn the phone right side up.
    • Insert your plastic opening tool between the screen and the outer case. Move the opening tool around the phone without removing it from in between the screen and the shell of the phone.
    • Pop the screen out of the outer shell. Be cautious not to damage the control board or the screen.
  7. Unscrew 4.4mm with a PH #000 marked screw. Unscrew 4.4mm with a PH #000 marked screw.
    • Unscrew 4.4mm with a PH #000 marked screw.
  8. With the flat head screw driver pull up the blue connector. With the flat head screw driver pull up the blue connector.
    • With the flat head screw driver pull up the blue connector.
  9. With you finger or prying tool pull back bottom module. With you finger or prying tool pull back bottom module. With you finger or prying tool pull back bottom module.
    • With you finger or prying tool pull back bottom module.
  10. Remove the internal battery using tweezers or your flat head screw driver. There is glue at the bottom keeping battery and chassis stuck together. There is glue at the bottom keeping battery and chassis stuck together.
    • Remove the internal battery using tweezers or your flat head screw driver.
    • There is glue at the bottom keeping battery and chassis stuck together.
  11. Peel the display connector strip off the main circuit board using the tweezers. Peel the USB connector strip off the main circuit board using the tweezers.
    • Peel the display connector strip off the main circuit board using the tweezers.
    • Peel the USB connector strip off the main circuit board using the tweezers.
  12. Remove the antenna using either your fingers or tweezers. Remove the antenna using either your fingers or tweezers. Remove the antenna using either your fingers or tweezers.
    • Remove the antenna using either your fingers or tweezers.
  13. Using tweezers, pull the top circuit board off. Depending on your model, there may be ribbon cable connectors attached to the underside of the board. Be careful not to rip them out of the sockets when removing the board. Depending on your model, there may be ribbon cable connectors attached to the underside of the board. Be careful not to rip them out of the sockets when removing the board.
    • Using tweezers, pull the top circuit board off.
    • Depending on your model, there may be ribbon cable connectors attached to the underside of the board. Be careful not to rip them out of the sockets when removing the board.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Stephan Williams
1.452 Reputatie
7 handleidingen geschreven
I believe the blue tool needs to be called the "plastic opening tool."
Dan Brown - Antwoord
were i can find mother board i need the mother board
bangera.kaushik990 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 6
Altijd: 3,739
