Ga door naar hoofdinhoud
Samsung Galaxy Mega Midframe Replacement
Wat je nodig hebt
  1. Samsung Galaxy Mega Midframe Replacement, Battery: stap 1, afbeelding 1 van 3 Samsung Galaxy Mega Midframe Replacement, Battery: stap 1, afbeelding 2 van 3 Samsung Galaxy Mega Midframe Replacement, Battery: stap 1, afbeelding 3 van 3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Midframe Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy Mega Midframe Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy Mega Midframe Replacement: stap 2, afbeelding 3 van 3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Midframe Replacement, Midframe: stap 3, afbeelding 1 van 3 Samsung Galaxy Mega Midframe Replacement, Midframe: stap 3, afbeelding 2 van 3 Samsung Galaxy Mega Midframe Replacement, Midframe: stap 3, afbeelding 3 van 3
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega Midframe Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy Mega Midframe Replacement: stap 4, afbeelding 2 van 2
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Aaron Fulton
1.246 Reputatie
3 handleidingen geschreven
USF Tampa, Team 17-2, Blackwell Winter 2016 Lid van USF Tampa, Team 17-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G2
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 1,095
