Ga door naar hoofdinhoud
Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement
Wat je nodig hebt
    1. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement, Screen & Digitizer Assembly: stap 1, afbeelding 1 van 1
      • Before beginning, make sure the phone is turned off.
      • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
      • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
      • Once the corner is released, slide your finger around the outside until the back cover releases.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: stap 2, afbeelding 2 van 2
      • Locate the battery.
      • Insert fingernail or plastic opening tool into the slot on the bottom of the battery and gently lift up.
      • Remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: stap 3, afbeelding 3 van 3
      • Use a phillips head PH000 and remove all 13, 1.4 mm visible screws.
      • Using the pry tool, carefully pop the Digitizer cover off the device.
      • Use the pry tool to disconnect the digitizer
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: stap 4, afbeelding 2 van 2
      • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembly frame.
      • Be careful and do not lift the screen completely off yet, leave the screen at an angle.
      • Use the heat gun to heat up the bottom to loosen the adhesive from the menu and back buttons.
      • Once heated, gently pull the screen upward.
      • Make sure that the buttons are separating from the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    5. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: stap 5, afbeelding 1 van 1
      • Now, seperate the screen from the outside frame of the phone (the bezel).
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
I want to repair my phone
Monirul Islam - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 38
Altijd: 1,803
