Ga door naar hoofdinhoud
Samsung Galaxy Mega 2 Rear Camera Replacement
Wat je nodig hebt
    1. Samsung Galaxy Mega 2 Rear Camera Replacement, Rear Camera: stap 1, afbeelding 1 van 1
      • Before beginning, make sure phone is turned off.
      • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
      • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
      • Once the corner is released, slide your finger around the outside until the back cover releases.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Galaxy Mega 2 Rear Camera Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Mega 2 Rear Camera Replacement: stap 2, afbeelding 2 van 2
      • Locate the battery.
      • Insert fingernail or plastic opening tool into the slot on the bottom of the battery and gently lift up.
      • Remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Galaxy Mega 2 Rear Camera Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy Mega 2 Rear Camera Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy Mega 2 Rear Camera Replacement: stap 3, afbeelding 3 van 3
      • Use phillips head PH000 and remove all 13, 1.4 mm visible screws.
      • Using the pry tool, carefully pop the Digitizer cover off the device.
      • Use pry tool to disconnect the digitizer.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung Galaxy Mega 2 Rear Camera Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Mega 2 Rear Camera Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Mega 2 Rear Camera Replacement: stap 4, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembling frame.
      • Remember once the screen is off to completely remove it from the mid-frame.
      • To remove the mid-frame from the motherboard, press down on the top right corner of the frame and the mid-frame should release from the motherboard.
      • When it releases use tweezers to pick up on the mid-frame to completely separate it from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Samsung Galaxy Mega 2 Rear Camera Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy Mega 2 Rear Camera Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy Mega 2 Rear Camera Replacement: stap 5, afbeelding 3 van 3
      • Once the rear assembly frame is removed you will see the motherboard and the connectors.
      • Locate the rear facing camera in the top middle of the phone.
      • Using tweezers lift up on the motherboard itself to disconnect it from the mid-frame.
      • Flip the motherboard over.
      • Use the tweezers to then disconnect the rear facing camera.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 37
Altijd: 1,154
