Ga door naar hoofdinhoud
Samsung Galaxy Mega 2 Front Facing Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy Mega 2 Front Facing Camera Replacement, Front Facing Camera: stap 1, afbeelding 1 van 1
    • Before beginning, make sure phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once the corner is released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 Front Facing Camera Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Mega 2 Front Facing Camera Replacement: stap 2, afbeelding 2 van 2
    • Locate the battery.
    • Use pry tool or fingernail to lift up on the battery.
    • Remove the battery.
  3. Samsung Galaxy Mega 2 Front Facing Camera Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use phillips head PH000 and remove all 13, 1.4 mm screws as shown.
    • Using the pry tool, carefully pop the Digitizer cover off the device.
    • Use tweezers to disconnect the digitizer.
  4. Samsung Galaxy Mega 2 Front Facing Camera Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: stap 4, afbeelding 3 van 3
    • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembling frame.
    • Remember once the screen is off, completely remove it from the mid-frame.
    • To remove the mid-frame from the motherboard, press down on the top right corner of the frame and the mid-frame should release from the motherboard.
    • When it releases use tweezers to pick up on the mid-frame to completely separate it from the motherboard.
  5. Samsung Galaxy Mega 2 Front Facing Camera Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: stap 5, afbeelding 3 van 3
    • Locate the camera in the top left corner.
    • Lift the motherboard connector and remove the camera assembly from phone.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 723
