Ga door naar hoofdinhoud
Samsung Galaxy Luna LCD display Replacement
Wat je nodig hebt
  1. Samsung Galaxy Luna LCD display Replacement, LCD display: stap 1, afbeelding 1 van 1
    • Attach a small suction cup to the lower half of the glass screen.
  2. Samsung Galaxy Luna LCD display Replacement: stap 2, afbeelding 1 van 1
    • Apply pressure to the middle section of the screen while pulling up the lower edge by pivoting your wrist.
  3. Samsung Galaxy Luna LCD display Replacement: stap 3, afbeelding 1 van 1
    • Once you've opened a large enough gap, insert a Spudger tool between the glass and the motherboard.
    • Slide the Spudger tool around the gap until the screen is completely separated from the motherboard.
    • The LCD is very fragile,be careful when sliding the spudger around the gap.
  4. Samsung Galaxy Luna LCD display Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy Luna LCD display Replacement: stap 4, afbeelding 2 van 2
    • Pull the rear panel up and away to completely separate it.
    • make sure the panel is completely detached from the phone frame before separating it.
  5. Samsung Galaxy Luna LCD display Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy Luna LCD display Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy Luna LCD display Replacement: stap 5, afbeelding 3 van 3
    • Place the spudger tool between the LCD and the glass screen.
    • Slide the spudger tool in between the screen and the display until both are completely separated from each other.
    • The LCD is very fragile, do not apply excessive force when prying the glass panel
Conclusie
xingyu chen
266 Reputatie
1 Handleiding geschreven
USF Tampa, Team S6-G1, Eyestone Spring 2018 Lid van USF Tampa, Team S6-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S6G1
4 Leden
5 handleidingen geschreven
2 opmerkingen
Hola, cual es el numero de parte de la pantalla a reemplazar?
Luis A. Andueza - Antwoord
It appears that OEM screens are no longer available for this phone. I was able to find this third party display assembly that looks like it would work, but I can’t attest to its functionality, so there would be a bit of risk involved for you. Hope that helps!
Austin Blakely -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 1,043
