Ga door naar hoofdinhoud
Samsung Galaxy Light Motherboard Replacement
Wat je nodig hebt
  1. Samsung Galaxy Light Motherboard Replacement, Remove Back Cover: stap 1, afbeelding 1 van 1
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Motherboard Replacement, Remove Battery: stap 2, afbeelding 1 van 1
    • Remove the battery from the device.
  3. Samsung Galaxy Light Motherboard Replacement, Unscrew Midframe: stap 3, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Motherboard Replacement, Remove Midframe: stap 4, afbeelding 1 van 1
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: stap 5, afbeelding 1 van 3 Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: stap 5, afbeelding 2 van 3 Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: stap 5, afbeelding 3 van 3
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Diandra
210 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 Lid van UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G2
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,115
