Ga door naar hoofdinhoud
Samsung Galaxy J7 v Volume Button Replacement
Wat je nodig hebt
  1. Samsung Galaxy J7 v Volume Button Replacement, Screen: stap 1, afbeelding 1 van 1
    • Be very careful during this step. The OLED (organic light-emitting diode) display is very fragile and can break easily.
    • Insert a Jimmy tool under one of the corners of the display and gently raise the display.
  2. Samsung Galaxy J7 v Volume Button Replacement: stap 2, afbeelding 1 van 1
    • Gently slide the Jimmy tool around the entire perimeter of the phone.
  3. Samsung Galaxy J7 v Volume Button Replacement: stap 3, afbeelding 1 van 1
    • Be extra careful with the display's ribbon cables. They are fragile.
    • Carefully lift the display to remove it.
  4. Samsung Galaxy J7 v Volume Button Replacement, Home button: stap 4, afbeelding 1 van 1
    • Locate the socket of the home button.
    • Fit the metal spudger in between the socket and the home button.
  5. Samsung Galaxy J7 v Volume Button Replacement: stap 5, afbeelding 1 van 1
    • Take the metal spudger and slide it underneath the home button.
    • Lift up until the home button is removed from its socket.
  6. Samsung Galaxy J7 v Volume Button Replacement, Volume Button: stap 6, afbeelding 1 van 2 Samsung Galaxy J7 v Volume Button Replacement, Volume Button: stap 6, afbeelding 2 van 2
    • Remove the screws around the home button and the screws above.
  7. Samsung Galaxy J7 v Volume Button Replacement: stap 7, afbeelding 1 van 1
    • Pull the screen away from the panel.
  8. Samsung Galaxy J7 v Volume Button Replacement: stap 8, afbeelding 1 van 2 Samsung Galaxy J7 v Volume Button Replacement: stap 8, afbeelding 2 van 2
    • Remove all adjacent screws.
  9. Samsung Galaxy J7 v Volume Button Replacement: stap 9, afbeelding 1 van 3 Samsung Galaxy J7 v Volume Button Replacement: stap 9, afbeelding 2 van 3 Samsung Galaxy J7 v Volume Button Replacement: stap 9, afbeelding 3 van 3
    • Pop off panel from plastic hold.
  10. Samsung Galaxy J7 v Volume Button Replacement: stap 10, afbeelding 1 van 3 Samsung Galaxy J7 v Volume Button Replacement: stap 10, afbeelding 2 van 3 Samsung Galaxy J7 v Volume Button Replacement: stap 10, afbeelding 3 van 3
    • Use the pointed end of the spudger to push down the button hold, then the volume button can be removed by pushing it down.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 30
Altijd: 879
