Inleiding
If you need to replace the motherboard of your Samsung Galaxy J3, follow this guide. One of the most important components in an electronic device is the motherboard. Likewise, the smartphone’s motherboard is also important for the device to operate and run effectively. If there is even a small issue in the motherboard of the smartphone, the smartphone would have problems functioning and performing even the simplest tasks. Damages to a motherboard can be identified easily by recognizing the symptoms as stated below:
1) An error code appears
2) The system doesn’t apply anything
3) Memory modules fail
4) The phone does not turn on
Wat je nodig hebt
Unplug the device from the charging dock if it is connected. Power off the device. Then using your fingernails, pop off the back cover of the device.
6 andere personen hebben deze handleiding voltooid.
