Inleiding
This guide will show you how to remove and replace your Samsung Galaxy J3 Mission screen, a simple procedure but one that could result in damage to the device if not done with caution and care.
Wat je nodig hebt
Insert your fingernail into the back cover removal slot and gently pull back until the cover pops off.
Insert your fingernail into the battery removal slot and pull back until the battery pops out.
Use an iFixit opening tool to lift the screen from one of the vertical sides of the phone and continue gently prying until the screen is loose enough to safely remove.
To install a new screen try the connector before adding any adhesive, then put it back together by following these steps in reverse order.
7 andere personen hebben deze handleiding voltooid.
