Ga door naar hoofdinhoud
Samsung Galaxy J3 Luna Pro Headphone jack Replacement
Wat je nodig hebt
  1. Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Motherboard Change: stap 1, afbeelding 1 van 1
    • Turn off the phone.
    • Remove the back cover and battery
  2. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: stap 2, afbeelding 3 van 3
    • Attach a suction cup to the screen and pry upwards.
    • Insert the plastic opening tool into the gap under the screen and work your way around the perimeter.
    • Don't remove the screen completely as there are cables still connection the two pieces.
  3. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: stap 3, afbeelding 3 van 3
    • Use the pointy end of a spudger to remove the white plastic cover from the display cover.
    • Use the spudger to pry up the display cable from the motherboard.
    • Remove the screen.
  4. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: stap 4, afbeelding 3 van 3
    • Remove the eleven JIS 00 screws from the mid-frame.
    • Using a spudger, pry the mid-frame from the screen.
  5. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: stap 5, afbeelding 3 van 3
    • Remove the motherboard from the mid-frame.
  6. Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Headphone jack: stap 6, afbeelding 1 van 2 Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Headphone jack: stap 6, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up the headphone jack cable connector from its socket on the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brandon Mendoza
673 Reputatie
2 handleidingen geschreven
USF Tampa, Team S5-G5, Passmore Spring 2018 Lid van USF Tampa, Team S5-G5, Passmore Spring 2018
USFT-PASSMORE-S18S5G5
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 1,222
