Ga door naar hoofdinhoud
Samsung Galaxy J3 Emerge Screen Replacement
Wat je nodig hebt
  1. Samsung Galaxy J3 Emerge Screen Replacement, Screen: stap 1, afbeelding 1 van 3 Samsung Galaxy J3 Emerge Screen Replacement, Screen: stap 1, afbeelding 2 van 3 Samsung Galaxy J3 Emerge Screen Replacement, Screen: stap 1, afbeelding 3 van 3
    • Heat up the edges of the screen with a hair dryer.
    • Put the iFixit Opening Tool between the screen and body to open the edge of the screen up.
    • Work the iFixit Opening Tools around the whole screen to break the glue.
  2. Samsung Galaxy J3 Emerge Screen Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy J3 Emerge Screen Replacement: stap 2, afbeelding 2 van 2
    • Lift the screen up from the bottom.
    • The screen could crack when lifting it up.
    • Pry the gray cover open.
  3. Samsung Galaxy J3 Emerge Screen Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy J3 Emerge Screen Replacement: stap 3, afbeelding 2 van 2
    • Pry the connector off of the motherboard by using a clean nail or the iFixit opening tool.
Conclusie
6 andere personen hebben deze handleiding voltooid.
PJ Yebisu
256 Reputatie
1 Handleiding geschreven
Cal Poly, Team S19-G2, White Winter 2019 Lid van Cal Poly, Team S19-G2, White Winter 2019
CPSU-WHITE-W19S19G2
4 Leden
5 handleidingen geschreven
2 opmerkingen
I was using my J3 Emerge last night and all of a sudden the screen just went blank. At first, I could press the power button and I would see the Samsung logo for a split second but now it doesn’t do that. You can tell it is trying to turn on because you can see it change from black to a blue like color. I thought it might be the battery so I took it to a store today to buy a new one but he said that wasn’t the problem. It is charging but I just can’t see anything. Do you think I need a new LCD screen or is it something else? Thank you!
theleachs - Antwoord
Gostei da aula parabens muito gratificante.
athoscost - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 25
Altijd: 3,049
