Ga door naar hoofdinhoud
Samsung Galaxy J1 Motherboard Replacement
Wat je nodig hebt
  1. Samsung Galaxy J1 Motherboard Replacement, Midframe: stap 1, afbeelding 1 van 1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Motherboard Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy J1 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Motherboard Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy J1 Motherboard Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy J1 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Samsung Galaxy J1 Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 2 Samsung Galaxy J1 Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 2
    • Use the flat edge of a spudger to disconnect the ear speaker connector.
  6. Samsung Galaxy J1 Motherboard Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy J1 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Use the flat end of a spudger disconnect the digitizer connector.
  7. Samsung Galaxy J1 Motherboard Replacement: stap 7, afbeelding 1 van 2 Samsung Galaxy J1 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Use the flat end of a spudger disconnect the front-facing camera cable connector.
  8. Samsung Galaxy J1 Motherboard Replacement: stap 8, afbeelding 1 van 2 Samsung Galaxy J1 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Remove the front-facing camera.
  9. Samsung Galaxy J1 Motherboard Replacement: stap 9, afbeelding 1 van 3 Samsung Galaxy J1 Motherboard Replacement: stap 9, afbeelding 2 van 3 Samsung Galaxy J1 Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Use the flat end of a spudger to gently pry under the motherboard.
    • Remove the motherboard.
  10. Samsung Galaxy J1 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Use the flat end of a spudger to disconnect the rear camera cable connector.
  11. Samsung Galaxy J1 Motherboard Replacement: stap 11, afbeelding 1 van 2 Samsung Galaxy J1 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Remove the rear camera.
Conclusie
22 andere personen hebben deze handleiding voltooid.
Sean Kramer
1.506 Reputatie
6 handleidingen geschreven
USF Tampa, Team S5-G4, Eyestone Spring 2018 Lid van USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 Leden
4 opmerkingen
can you plz give use a amazon link to part
Sean Gynn - Antwoord
Very good illustration..where can I get a motherboard?
Isaac Samuels - Antwoord
Where can I get a motherboard for this phone Samsung J100?
I need the details of the motherboard
FUN FIRST - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 52
Altijd: 6,774
