Ga door naar hoofdinhoud
Samsung Galaxy J1 Glass Screen Replacement
Wat je nodig hebt
  1. Samsung Galaxy J1 Glass Screen Replacement, Midframe: stap 1, afbeelding 1 van 1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Glass Screen Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy J1 Glass Screen Replacement: stap 2, afbeelding 2 van 2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Glass Screen Replacement: stap 3, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Glass Screen Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy J1 Glass Screen Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy J1 Glass Screen Replacement: stap 4, afbeelding 3 van 3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Samsung Galaxy J1 Glass Screen Replacement, Glass Screen: stap 5, afbeelding 1 van 2 Samsung Galaxy J1 Glass Screen Replacement, Glass Screen: stap 5, afbeelding 2 van 2
    • Using the flat end of a spudger, disconnect the digitizer cable connector.
  6. Samsung Galaxy J1 Glass Screen Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy J1 Glass Screen Replacement: stap 6, afbeelding 2 van 2
    • Using a plastic opening tool pry between silver digitizer and black back piece.
    • Slowly slide plastic opening tool around the screen to loosen the adhesive.
    • Be careful not to tear the digitizer cable when threading it through the plastic housing.
  7. Samsung Galaxy J1 Glass Screen Replacement: stap 7, afbeelding 1 van 1
    • Carefully separate display assembly from the plastic housing.
Conclusie
23 andere personen hebben deze handleiding voltooid.
Sean Kramer
1.593 Reputatie
6 handleidingen geschreven
USF Tampa, Team S5-G4, Eyestone Spring 2018 Lid van USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 Leden
8 handleidingen geschreven
2Gids Commentaar
In my Samsung J110h, Some of the right side keys in keyboard not working. They are P, Zero, In message screen, the sending button etc..
I am in desperate need for advice to rectify.
Will somebody help me.
My mail Id”: karupusolai@gmail.com
Solaimalai - Antwoord Deel
I was having the display issue. So I bought Samsung Galaxy J1 Screen replacement. And, I replaced it by myself using the information in this.
harshithaemazel - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 86
Altijd: 5,797
