Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
How to disassemble and replace the Touch screen digitizer and the LCD display.
Video overzicht
  1. Here we have Samsung Galaxy J1 with broken glass and screen. We will replace the touch screen and the LCD. First remove the battery and any installed SIM and memory cards.
    • Here we have Samsung Galaxy J1 with broken glass and screen.
    • We will replace the touch screen and the LCD.
    • First remove the battery and any installed SIM and memory cards.
  2. Under this plastic is the LCD flex cable connector. Use a tool with a needlepoint and remove it. Use a tool with a needlepoint and remove it.
    • Under this plastic is the LCD flex cable connector.
    • Use a tool with a needlepoint and remove it.
  3. Disconnect the LCD flex cable. When I can, I always test new replacement part before I install it. When I can, I always test new replacement part before I install it.
    • Disconnect the LCD flex cable.
    • When I can, I always test new replacement part before I install it.
  4. OPEN ALLE TABBLADEN
    RAM-upgradekits voor Mac
    Koop kits
    Genoeg RAM
    voor al je tabbladen
    Koop kits
  5. Use hot air to warm the glass and to make adhesive soften. With a cutter or knife start the separation. When you have enough space between the glass and the frame, continue with a plastic tool.
    • Use hot air to warm the glass and to make adhesive soften.
    • With a cutter or knife start the separation.
    • When you have enough space between the glass and the frame, continue with a plastic tool.
  6. You can warm the glass again to make the separation more easy. If you want to change only the touch screen, be careful, don't break the LCD. Finally remove the screen and the glass from the frame.
    • You can warm the glass again to make the separation more easy.
    • If you want to change only the touch screen, be careful, don't break the LCD.
    • Finally remove the screen and the glass from the frame.
  7. If you want to change only the glass, disconnect the touch screen flex cable and gently separate the glass from the LCD. If you want to change only the glass, disconnect the touch screen flex cable and gently separate the glass from the LCD. If you want to change only the glass, disconnect the touch screen flex cable and gently separate the glass from the LCD.
    • If you want to change only the glass, disconnect the touch screen flex cable and gently separate the glass from the LCD.
  8. Connect the touch screen to the LCD flex cable. Put the LCD and the screen in their place. Remove the protector from the touch screen.
    • Connect the touch screen to the LCD flex cable.
    • Put the LCD and the screen in their place.
    • Remove the protector from the touch screen.
    • Install the earpiece metal plate - take it from the old touch screen.
    • Remove the protector from the LCD (if it's new).
  9. Connect the LCD flex cable and you are ready. Connect the LCD flex cable and you are ready.
    • Connect the LCD flex cable and you are ready.
Conclusie
107 andere personen hebben deze handleiding voltooid.
ZFix
173.412 Reputatie
308 handleidingen geschreven
Master Techs Lid van Master Techs
Community
294 Leden
950 handleidingen geschreven
Bonjour, ou peux t on trouver l'écran et la vitre de protection ? Merci d'avance
Romain - Antwoord
How much is the cost for Galaxy J1 replacement glass?
Charles Young - Antwoord
It costs from 18€ up to 25€.
Johannes Franzen -
Gracias bro .. se ve interesante el único problema es que no se muy bien el ingles
Luis Fernando Ibarra casquete - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 80
Afgelopen 30 dagen: 419
Altijd: 140,231
