Ga door naar hoofdinhoud
Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement
Wat je nodig hebt
  1. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: stap 1, afbeelding 1 van 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: stap 1, afbeelding 2 van 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: stap 2, afbeelding 1 van 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: stap 2, afbeelding 2 van 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: stap 2, afbeelding 3 van 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: stap 3, afbeelding 1 van 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: stap 3, afbeelding 2 van 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: stap 3, afbeelding 3 van 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: stap 4, afbeelding 2 van 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: stap 5, afbeelding 2 van 2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: stap 6, afbeelding 1 van 2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: stap 6, afbeelding 2 van 2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
Conclusie
30 andere personen hebben deze handleiding voltooid.
Kyle Ruff
6.725 Reputatie
5 handleidingen geschreven
USF Tampa, Team 17-3, Blackwell Winter 2016 Lid van USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 Leden
12 handleidingen geschreven
3 opmerkingen
i seem to find myself with the speaker of microphone connected to the back of the housing.. where as i see your photo in step 5 does't have this. how can I replace this element?
jennpindakaas - Antwoord
I do this but i think my circuit have problem. When i insert aux, the sound play mono. The phone setting is stereo…..
How can i fix this problem?
Replay me on rabbanihootan71@gmail.com
Hootan Rabbani - Antwoord
How to me a memory card a default storage on grand prime
Ayandaundetsco - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 35,943
