Ga door naar hoofdinhoud
Samsung Galaxy Gear Band Replacement
Wat je nodig hebt
  1. Samsung Galaxy Gear Band Replacement, Display Housing: stap 1, afbeelding 1 van 1
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Band Replacement: stap 2, afbeelding 1 van 1
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Band Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy Gear Band Replacement: stap 3, afbeelding 2 van 2
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
  4. Samsung Galaxy Gear Band Replacement, Band: stap 4, afbeelding 1 van 1
    • Loosen the camera ribbon so it will easily pass through the watch body.
  5. Samsung Galaxy Gear Band Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy Gear Band Replacement: stap 5, afbeelding 2 van 2
    • Grip the body of the watch and pull the band upward.
    • Do the same with the adjacent band, but there will be no camera ribbon to pass through the watch body.
Conclusie
13 andere personen hebben deze handleiding voltooid.
Dalt Lasell
543 Reputatie
2 handleidingen geschreven
Cal Poly, Team 1-9, Maness Spring 2016 Lid van Cal Poly, Team 1-9, Maness Spring 2016
CPSU-MANESS-S16S1G9
4 Leden
7 handleidingen geschreven
8 opmerkingen
I have the non camera band (the one with holes )to be changed only. .... but I don't know where to buy it from and how to make sure that it will be the right one for this model SM- v700
Naji
Naji Ajaleel Ibrahim - Antwoord
Is there a shop in London where I can have this Band changed and repaired by themselves ?
Naji
Absolutely brilliant instructions. Many thanks.
On mine two of the screws were T5 Torx and the other two were T6 Torx, so something to look for.
Roger Palmer - Antwoord
Please advise are you able to ship to Pakistan
Mehboob Mehmood - Antwoord
These are very helpful but could do with one more step and pic at the end - for how to swap out the embedded camera.
Dan Bloch - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 18,596
