1. Turn the phone off and make sure your hands are clean. Use your thumb nail or a plastic spudger to pry open the back cover,
    • Turn the phone off and make sure your hands are clean. Use your thumb nail or a plastic spudger to pry open the back cover,
  2. Use the plastic opening tool or your thumb nail to lift the battery out of the receptacle.
    • Use the plastic opening tool or your thumb nail to lift the battery out of the receptacle.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  4. Remove the five 4 mm screws with a Phillips#00 screwdriver. Make sure you remove the sticker hiding the screw on the left bottom corner. Make sure you remove the sticker hiding the screw on the left bottom corner.
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
    • Make sure you remove the sticker hiding the screw on the left bottom corner.
  5. Using the plastic opening tool pry into the bezel to remove the mid-frame Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  6. After separating the two frames, you will have access to the camera
    • After separating the two frames, you will have access to the camera
  7. Pull the camera off the system by using the tweezers. Perform this step with caution.
    • Pull the camera off the system by using the tweezers. Perform this step with caution.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Charles
133 Reputatie
2 handleidingen geschreven
USF Tampa, Team 8-2, Leahy Fall 2014 Lid van USF Tampa, Team 8-2, Leahy Fall 2014
USFT-LEAHY-F14S8G2
4 Leden
5 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 5
Altijd: 792
