Ga door naar hoofdinhoud
Samsung Galaxy Express 3 Rear Camera Lens Replacement
Wat je nodig hebt
  1. Samsung Galaxy Express 3 Rear Camera Lens Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung Galaxy Express 3 Rear Camera Lens Replacement, Battery: stap 1, afbeelding 2 van 2
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Rear Camera Lens Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy Express 3 Rear Camera Lens Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy Express 3 Rear Camera Lens Replacement: stap 2, afbeelding 3 van 3
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
  3. Samsung Galaxy Express 3 Rear Camera Lens Replacement, Rear Camera Lens: stap 3, afbeelding 1 van 1
    • Carefully push a small pointed tool such as a plastic opening tool (or metal spudger if needed) underneath the camera lens in a corner.
    • Pry up each corner of the lens.
    • Be careful, especially if using the metal spudger, as if you push to hard it can cause damage to the device or yourself.
  4. Samsung Galaxy Express 3 Rear Camera Lens Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy Express 3 Rear Camera Lens Replacement: stap 4, afbeelding 2 van 2
    • Slide your tool underneath one corner to the other to release the lens.
    • Make sure not to insert your tool too far as it can damage the camera.
    • When putting the new lens in make sure not to put to much force on it as it can break again.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 516
