Inleiding
This guide will take you through the steps to replace the motherboard or the zoom lens. Both parts follow the same process until the very last step.
Wat je nodig hebt
Gather your camera and tools. Also make sure that the battery is removed before proceeding.
Follow battery replacement guide through step three to remove the battery.
Open the battery compartment and remove the 2 screws. Also remove the screw from the bottom of the camera after pulling off the white sticker concealing it. Removing these screws releases the bottom of the display assembly.
Starting at the non-lens side of the camera, use plastic opening tool to pry screen away from main housing on all sides.
8 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Would love a video of this, as well.
