Ga door naar hoofdinhoud
Samsung Galaxy Camera Capture button Replacement
Wat je nodig hebt
  1. Samsung Galaxy Camera Capture button Replacement, Screen: stap 1, afbeelding 1 van 1
    • Begin removing the 3/16" screws for the device.
  2. Samsung Galaxy Camera Capture button Replacement: stap 2, afbeelding 1 van 1
    • Turn the device and remove the additional 3/16" screws.
  3. Samsung Galaxy Camera Capture button Replacement: stap 3, afbeelding 1 van 1
    • Turn the device and remove the additional 3/16" screw.
  4. Samsung Galaxy Camera Capture button Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Camera Capture button Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Camera Capture button Replacement: stap 4, afbeelding 3 van 3
    • Take the white cover plate off.
  5. Samsung Galaxy Camera Capture button Replacement: stap 5, afbeelding 1 van 1
    • Using the plastic opening tools, pry open the camera from the bottom.
    • This may require a moderate use of force because of the sealing glue.
  6. Samsung Galaxy Camera Capture button Replacement: stap 6, afbeelding 1 van 1
    • Gently pull the connector away from the motherboard.
  7. Samsung Galaxy Camera Capture button Replacement, Lens and Motherboard: stap 7, afbeelding 1 van 1
    • Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
  8. Samsung Galaxy Camera Capture button Replacement: stap 8, afbeelding 1 van 1
    • Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
  9. Samsung Galaxy Camera Capture button Replacement: stap 9, afbeelding 1 van 1
    • Pull these connectors away from motherboard.
  10. Samsung Galaxy Camera Capture button Replacement: stap 10, afbeelding 1 van 1
    • Lift the motherboard and lens out of the case.
  11. Samsung Galaxy Camera Capture button Replacement, Unscrew: stap 11, afbeelding 1 van 1
    • Remove all the screws circled. There is 1 1/8" screw by the flash, 1 9/32" screw that holds the flash button, 2 5/32" screw that is on the grey frame for the flash, and 2 5/32" screws that holds the cable frames on the top left.
  12. Samsung Galaxy Camera Capture button Replacement: stap 12, afbeelding 1 van 1
    • Unscrew the 3 5/32" screws that cover the battery plate.
  13. Samsung Galaxy Camera Capture button Replacement: stap 13, afbeelding 1 van 1
    • The black plates on the other side can be removed after these screws.
  14. Samsung Galaxy Camera Capture button Replacement: stap 14, afbeelding 1 van 1
    • Pull the flash and battery case out of the device.
  15. Samsung Galaxy Camera Capture button Replacement, Capture button: stap 15, afbeelding 1 van 1
    • Unscrew the 2 5/32" screws on the grey plate.
  16. Samsung Galaxy Camera Capture button Replacement: stap 16, afbeelding 1 van 1
    • Pull the plate aside and unscrew 2 1/8" screws on the button.
  17. Samsung Galaxy Camera Capture button Replacement: stap 17, afbeelding 1 van 1
    • The Capture button can now be removed.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Richard Hicks
1.280 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-3, Sullivan Winter 2015 Lid van USF Tampa, Team 1-3, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G3
3 Leden
6Gids Commentaar
Thank you very much for these instructions - they enabled me to fix the camera after four repair places refused to.
(the two screws holding the shutter button in place had come loose - the button had fallen off and the loose screws inside were interfering with the zoom switch, sending the camera always to safe mode)
A couple of things: It is not necessary to remove the black screws at step 8. They hold something in place in the lens assembly, but don't prevent you from moving to step 10. Also, it is not necessary to remove the screws at step 11 - only the leftmost one in the image. If you are careful of the wires, the battery case can be folded back giving adequate access to the shutter assembly.
Also - when reassembling, be careful at step 17 that the zoom lever is positioned to be engaged with (hooked over) the lever on the brown circuit board.
danridleyellis - Antwoord Deel
It's a good and detailed instruction, but it also has mistakes (see my comments to steps 8, 11 and 15).
NOVOMOTION J. H. - Antwoord Deel
Thank You so much for the help! I would have never been able to replace the button without these instructions. You are a lifesaver.
Karen Rose - Antwoord Deel
Dis assembly has been educational and all ,but where do I get my new button???????
Paul Rice - Antwoord Deel
I realize the I wouldn't have been able to get this camara apart without the instructions. Very helpful and I do thank you Mr. Hicks. But I didn't want to take it apart. I want to fix it… and put it back together….and use it…perhaps just maybe take a photo or two. So please may I ask for information on obtaining a replacement capture/ zoom button assembly/ parts?????
Paul Rice - Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 105
Altijd: 3,299
