Ga door naar hoofdinhoud
Samsung Galaxy Camera Camera Flash Replacement
Wat je nodig hebt
  1. Samsung Galaxy Camera Camera Flash Replacement, Screen: stap 1, afbeelding 1 van 1
    • Begin removing the 3/16" screws for the device.
  2. Samsung Galaxy Camera Camera Flash Replacement: stap 2, afbeelding 1 van 1
    • Turn the device and remove the additional 3/16" screws.
  3. Samsung Galaxy Camera Camera Flash Replacement: stap 3, afbeelding 1 van 1
    • Turn the device and remove the additional 3/16" screw.
  4. Samsung Galaxy Camera Camera Flash Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Camera Camera Flash Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Camera Camera Flash Replacement: stap 4, afbeelding 3 van 3
    • Take the white cover plate off.
  5. Samsung Galaxy Camera Camera Flash Replacement: stap 5, afbeelding 1 van 1
    • Using the plastic opening tools, pry open the camera from the bottom.
    • This may require a moderate use of force because of the sealing glue.
  6. Samsung Galaxy Camera Camera Flash Replacement: stap 6, afbeelding 1 van 1
    • Gently pull the connector away from the motherboard.
  7. Samsung Galaxy Camera Camera Flash Replacement, Lens and Motherboard: stap 7, afbeelding 1 van 1
    • Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
  8. Samsung Galaxy Camera Camera Flash Replacement: stap 8, afbeelding 1 van 1
    • Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
  9. Samsung Galaxy Camera Camera Flash Replacement: stap 9, afbeelding 1 van 1
    • Pull these connectors away from motherboard.
  10. Samsung Galaxy Camera Camera Flash Replacement: stap 10, afbeelding 1 van 1
    • Lift the motherboard and lens out of the case.
  11. Samsung Galaxy Camera Camera Flash Replacement, Unscrew: stap 11, afbeelding 1 van 1
    • Remove all the screws circled. There is 1 1/8" screw by the flash, 1 9/32" screw that holds the flash button, 2 5/32" screw that is on the grey frame for the flash, and 2 5/32" screws that holds the cable frames on the top left.
  12. Samsung Galaxy Camera Camera Flash Replacement: stap 12, afbeelding 1 van 1
    • Unscrew the 3 5/32" screws that cover the battery plate.
  13. Samsung Galaxy Camera Camera Flash Replacement: stap 13, afbeelding 1 van 1
    • The black plates on the other side can be removed after these screws.
  14. Samsung Galaxy Camera Camera Flash Replacement: stap 14, afbeelding 1 van 1
    • Pull the flash and battery case out of the device.
Conclusie
13 andere personen hebben deze handleiding voltooid.
Richard Hicks
1.280 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-3, Sullivan Winter 2015 Lid van USF Tampa, Team 1-3, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G3
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 34
Altijd: 1,078
