Inleiding
Remove the speaker/rear camera assembly from the Samsung Galaxy Attain 4G. This assembly includes the vibrator, rear-facing camera, flash, and loudspeaker.
Wat je nodig hebt
At the top of the device there is a small notch that is used to remove the battery door.
Using a pry tool or your fingernail, pry off the battery door from the main housing.
Place the battery door to the side.
Using a pry tool or your fingernail, pry the battery up towards you.
You have now removed the battery!
Remove the 6 Phillips head screws that hold the rear housing in place.
Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
Using your spudger/plastic pry tool, disconnect the headphone jack flex cable.
Flip the logic board to the rear side, and using a spudger/plastic pry tool to disconnect the rear camera flex cable.
