Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
  1. Begin by turn the device over to it's back, with the screen facing down.
    • Begin by turn the device over to it's back, with the screen facing down.
  2. At the top of the device there is a small notch that is used to remove the battery door. Using a pry tool or your fingernail, pry off the battery door from the main housing.
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. Place the battery door to the side. Using a pry tool or your fingernail, pry the battery up towards you. You have now removed the battery!
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  4. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  5. Make sure when replacing the battery that the arrow on the bottom is facing down.
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
  6. Remove the 6 Phillips head screws that hold the rear housing in place.
    • Remove the 6 Phillips head screws that hold the rear housing in place.
  7. Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
    • Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
  8. Lift the rear housing from the display assembly.
    • Lift the rear housing from the display assembly.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Josh Forester
2.377 Reputatie
10 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 169
