Ga door naar hoofdinhoud
Samsung Galaxy Amp 2 Motherboard Replacement
Wat je nodig hebt
  1. Samsung Galaxy Amp 2 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung Galaxy Amp 2 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
    • Lift upwards and gently pry the rear panel off of the phone.
  2. Samsung Galaxy Amp 2 Motherboard Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy Amp 2 Motherboard Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy Amp 2 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
    • Grip the battery and safely remove it from the phone.
  3. Samsung Galaxy Amp 2 Motherboard Replacement, Screen: stap 3, afbeelding 1 van 3 Samsung Galaxy Amp 2 Motherboard Replacement, Screen: stap 3, afbeelding 2 van 3 Samsung Galaxy Amp 2 Motherboard Replacement, Screen: stap 3, afbeelding 3 van 3
    • Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
    • Disconnect the connector piece from the back panel.
  4. Samsung Galaxy Amp 2 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
  5. Samsung Galaxy Amp 2 Motherboard Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy Amp 2 Motherboard Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy Amp 2 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Use four plastic opening tools to gently pry off the screen.
    • Optional: Use a suction tool to pull the screen off.
  6. Samsung Galaxy Amp 2 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 3 Samsung Galaxy Amp 2 Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 3 Samsung Galaxy Amp 2 Motherboard Replacement, Motherboard: stap 6, afbeelding 3 van 3
    • Unscrew the nine 4.5mm PH screws using a screwdriver with a PH000 bit.
    • Push from the back panel to remove the bottom part of the motherboard.
    • Push from the front panel to remove the top part of the motherboard.
Conclusie
Cory Nickolatos
409 Reputatie
4 handleidingen geschreven
UW Tacoma, Team S1-G1, Cardinal Summer 2018 Lid van UW Tacoma, Team S1-G1, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G1
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 759
