Ga door naar hoofdinhoud
Samsung Galaxy Alpha Battery Replacement
  1. Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: stap 1, afbeelding 1 van 3 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: stap 1, afbeelding 2 van 3 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: stap 1, afbeelding 3 van 3
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Samsung Galaxy Alpha Battery Replacement, Battery: stap 2, afbeelding 1 van 2 Samsung Galaxy Alpha Battery Replacement, Battery: stap 2, afbeelding 2 van 2
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Jon Brausch
1.542 Reputatie
2 handleidingen geschreven
Cal Poly, Team 20-17, Maness Winter 2015 Lid van Cal Poly, Team 20-17, Maness Winter 2015
CPSU-MANESS-W15S20G17
4 Leden
5 handleidingen geschreven
2 opmerkingen
Not even a full picture of the battery agh! I need to know if I can use note 4 battery
Alex Andrei - Antwoord
Please also make sure that replacing the battery with a cheap knock off will disable NFC since the antenna is glued to the battery.
vargabp0 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 31
Altijd: 4,994
