Ga door naar hoofdinhoud
Samsung Galaxy A8 (2018) Display Replacement
Wat je nodig hebt
  1. Samsung Galaxy A8  (2018) Display Replacement, Display: stap 1, afbeelding 1 van 1
    • Before proceeding to change the screen of your Galaxy A8 (2018), press and hold the power button to turn off your device.
  2. Samsung Galaxy A8  (2018) Display Replacement: stap 2, afbeelding 1 van 1
    • Insert the SIM Card Ejection tool into the small hole and remove the SIM Card tray.
  3. Samsung Galaxy A8  (2018) Display Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy A8  (2018) Display Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy A8  (2018) Display Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • Using a hairdryer, heat up the back of the device to loosen the adhesive.
    • Gently insert a plastic card and opening pick between the glass and frame to create an opening. Carefully separate the rear glass from the rest of the device.
    • Be careful not to overheat the rear glass since it is very fragile.
  4. Samsung Galaxy A8  (2018) Display Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy A8  (2018) Display Replacement: stap 4, afbeelding 2 van 2
    Koop
    • Using a pair of tweezers, disconnect the clip connecting camera and motherboard.
    • Lift the back panel off of the chassis of the device.
  5. Samsung Galaxy A8  (2018) Display Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy A8  (2018) Display Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy A8  (2018) Display Replacement: stap 5, afbeelding 3 van 3
    • Use the P2 Pentalobe screwdriver to remove the 14 (0.8mm) screws.
    • Use the Phillips #0 screwdriver to remove the rest of the four 1.5mm screws.
    • Gently leverage with the spudger under the top antenna to lift it.
    • Continue with the spudger to lift and extract the NFC antenna.
  6. Samsung Galaxy A8  (2018) Display Replacement: stap 6, afbeelding 1 van 3 Samsung Galaxy A8  (2018) Display Replacement: stap 6, afbeelding 2 van 3 Samsung Galaxy A8  (2018) Display Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the battery using the spudger.
    • Gently lift the speaker and pull it out of the slot.
    • Disconnect the display cables from the device.
  7. Samsung Galaxy A8  (2018) Display Replacement: stap 7, afbeelding 1 van 3 Samsung Galaxy A8  (2018) Display Replacement: stap 7, afbeelding 2 van 3 Samsung Galaxy A8  (2018) Display Replacement: stap 7, afbeelding 3 van 3
    • To soften the adhesive that binds the display panel to the chassis, heat the front panel with the hairdryer for a few seconds
    • To create an opening, insert the opening pick gently between the screen and the chassis
    • Gently slide the plastic card around the screen to take it off the chassis.
    • Be careful not to overheat the centre of the display panel as this can damage it.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Prayanshu Singla
428 Reputatie
1 Handleiding geschreven
Één opmerking
My microphone isnt working please help
alpadarkshadow - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 178
Altijd: 8,027
