Wat je nodig hebt
Video-instructies
Bijna klaar!
Eindstreep
40 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
fr en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
9 opmerkingen
Good video!!
Mandy - Antwoord
Good video!
I have a question though. What did you use to bull back the back partbof the phone at the end of the video? You simply heated the glue that was already there?
Mattia Rappuoli - Antwoord
Please answer, what is the glue you used in the video? Thanks.
tcatt - Antwoord
The glue used here is the B7000 glue, which can be found on this site under tools or from aliexpress.com.
However, it should be mentioned that it is not required to use other glue than the sticky tape than phone already has, unless you are serious about waterproofing. I removed 98% of all the sticky tape that was there hoping it would be easier to open later. Funny thing is that I still have to use heat lol. Hard to remove all that sticky.
lightmeupper - Antwoord
The tool to pull back the cover is Suction Handle
Something tells me it may work with a 40-50mm diameter suction cup from dollar store as well :-)
I mange to replace the screen and start the phone up. But now the power Button dosen work. Whan can i do?
Johan Fritiofsson - Antwoord
So i just had to put the screws in again… Puh
Johan Fritiofsson -
Hi,
I can’t get the home button to be in the right position, its too much inside, it gotta be pushed up a bit but I can’t get it there, how do I do that?
Max Hi - Antwoord
be cautious using a metal “opening tool”, higher risk of damaging the logic board and guaranteed to scratch up the metal frame. having an abundance of plastic tools is better in this case. metal is good to create the initial gap but, plastic is better once you have created a gap.
Andrew - Antwoord
