Ga door naar hoofdinhoud
How to diagnose Samsung Galaxy A40 Charging Problems
Video overzicht
  1. How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: stap 1, afbeelding 1 van 3 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: stap 1, afbeelding 2 van 3 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: stap 1, afbeelding 3 van 3
    • This is the +5V line from the Charging port to the Motherboard.
  2. How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: stap 2, afbeelding 1 van 3 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: stap 2, afbeelding 2 van 3 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: stap 2, afbeelding 3 van 3
    • Warm the device to soften the adhesive.
    • Use Sanction cup, Plastic tools and isopropyl alcohol.
    • Remove the silver Phillips screws from the device's frame.
  3. How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: stap 3, afbeelding 1 van 3 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: stap 3, afbeelding 2 van 3 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: stap 3, afbeelding 3 van 3
    • Remove the plastic cap from the Fingerprint flex cable connector and disconnect the cable.
    • Remove the SIM Tray.
  4. How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: stap 4, afbeelding 1 van 3 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: stap 4, afbeelding 2 van 3 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: stap 4, afbeelding 3 van 3
    • Use a plastic tool to separate the back cover from the frame. Start from the SIM tray hole.
    • Disconnect the battery.
  5. How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: stap 5, afbeelding 1 van 3 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: stap 5, afbeelding 2 van 3 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: stap 5, afbeelding 3 van 3
    • Disconnect the main flex cable and connect the charger.
    • Use a multimeter to measure the voltages at the large end pins of the FPC connector of the charging board. (See the second image)
    • If the reading is okay (~5V) continue with the next step, if not - change the Charging board.
    • Attach the main flex cable and measure the large end pins of the Main flex FPC connector - pic.3.
    • If the reading is okay, continue with the next step, if not - change the Main flex cable.
  6. How to diagnose Samsung Galaxy A40 Charging Problems: stap 6, afbeelding 1 van 3 How to diagnose Samsung Galaxy A40 Charging Problems: stap 6, afbeelding 2 van 3 How to diagnose Samsung Galaxy A40 Charging Problems: stap 6, afbeelding 3 van 3
    • Remove the adhesive rubber around the main flex connector on the logic board.
    • Use some flux and a soldering iron to re-solder the first pin of the motherboard FPC.
Conclusie
4 andere personen hebben deze handleiding voltooid.
ZFix
191.278 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.528 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 209
Altijd: 7,965
