Ga door naar hoofdinhoud
Samsung Galaxy A40 Charging Board Replacement
Wat je nodig hebt
Video overzicht
  1. Samsung Galaxy A40 Charging Board Replacement, Charging Dock / Charging Board: stap 1, afbeelding 1 van 2 Samsung Galaxy A40 Charging Board Replacement, Charging Dock / Charging Board: stap 1, afbeelding 2 van 2
    • The spare part: Daughter board with Charging port, Microphone, Main flex cable connector, display connector, 3G, 4G antennas
  2. Samsung Galaxy A40 Charging Board Replacement, Remove the Back Cover: stap 2, afbeelding 1 van 3 Samsung Galaxy A40 Charging Board Replacement, Remove the Back Cover: stap 2, afbeelding 2 van 3 Samsung Galaxy A40 Charging Board Replacement, Remove the Back Cover: stap 2, afbeelding 3 van 3
    • Turn off the device by pressing and holding the small button on the right side. After a few seconds, press the Power Off button and wait until the device has completely shut off
    • To soften the adhesive, use a heat gun or heating pad to warm up the device.
    • Use a Spudger (Or playing card) , Suction Cup, and Isopropyl alcohol to separate the back cover.
  3. Samsung Galaxy A40 Charging Board Replacement, Remove the  Sim Card Tray/Fingerprint Sensor: stap 3, afbeelding 1 van 3 Samsung Galaxy A40 Charging Board Replacement, Remove the  Sim Card Tray/Fingerprint Sensor: stap 3, afbeelding 2 van 3 Samsung Galaxy A40 Charging Board Replacement, Remove the  Sim Card Tray/Fingerprint Sensor: stap 3, afbeelding 3 van 3
    • Be very careful when removing the ribbons in this step! Damaging the ribbons may cause parts of your phone to stop working
    • Remove the SIM tray.
    • Remove the plastic cover that covers the Fingerprint flex connector.
    • Disconnect the Fingerprint Sensor.
  4. Samsung Galaxy A40 Charging Board Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy A40 Charging Board Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy A40 Charging Board Replacement: stap 4, afbeelding 3 van 3
    • Remove the 13 screws
    • Remove the back cover
  5. Samsung Galaxy A40 Charging Board Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy A40 Charging Board Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the Main flex cable, Display flex cable and the Coaxial antenna cable.
    • Remove the black screw securing the charging board.
  6. Samsung Galaxy A40 Charging Board Replacement: stap 6, afbeelding 1 van 3 Samsung Galaxy A40 Charging Board Replacement: stap 6, afbeelding 2 van 3 Samsung Galaxy A40 Charging Board Replacement: stap 6, afbeelding 3 van 3
    • Use Plastic tool to separate the charging board from the frame.
    • Warm the charging board slightly to make it easier to disassemble.
    • Now, install the new board and test the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
ZFix
188.535 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
312 Leden
1.298 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 177
Altijd: 3,652
