Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
To complete the repair follow instructions from the tutorial. If you need any further info feel free to comment below the video.
17 andere personen hebben deze handleiding voltooid.
5 opmerkingen
I have a Galaxy A3 model. it fell in water while using it. It switched off then after some minutes it restarted but the screen started misbehaving like opening multiple apps on the phone. the following day the touch screen couldn’t respond but it was on showing my lockscreen but it wasn’t responding. I took it to repair and the guy told me the only option was replacing the whole screen… I dont know if thats the only option or if the glass is replaced could solve the problem.
The technician i s probably right, you need to replace the whole display.
مانعرف ع
After separating the glass and the LCD there was lots of glue on the LCD. How did you remove it that it became so neat n clean???
Hi Siamak, you may try and get rid of the remaining adhesive with isopropyl alcohol (>97%)
