Ga door naar hoofdinhoud
Samsung Galaxy A22/A22 5G Screen Replacement
Wat je nodig hebt
  1. Samsung Galaxy A22/A22 5G Screen Replacement, Remove Sim card   Take cover off: stap 1, afbeelding 1 van 3 Samsung Galaxy A22/A22 5G Screen Replacement, Remove Sim card   Take cover off: stap 1, afbeelding 2 van 3 Samsung Galaxy A22/A22 5G Screen Replacement, Remove Sim card   Take cover off: stap 1, afbeelding 3 van 3
    • Firstly remove the Sim card .
    • start heating the back of the phone all around the edges of the back with an iOpener or aheat gun
    • start moving your pry card start around the edges of the phone to remove the adhesive it will take some time be patient and do it with care
    • mind the 2 cables in the middle of the phone don't damage them
  2. Samsung Galaxy A22/A22 5G Screen Replacement, Remove inner plastic frame: stap 2, afbeelding 1 van 2 Samsung Galaxy A22/A22 5G Screen Replacement, Remove inner plastic frame: stap 2, afbeelding 2 van 2
    • When you open the back start taking of the screws of the top of the phone and bottom of the frame
    • Then with a pry card remove the inner plastic frame of the phone carefully go all around the phone to take off the frame
    • You should remove the wire connected from the frame to the phone
  3. Samsung Galaxy A22/A22 5G Screen Replacement, Remove ribbons and bspeaker housing: stap 3, afbeelding 1 van 2 Samsung Galaxy A22/A22 5G Screen Replacement, Remove ribbons and bspeaker housing: stap 3, afbeelding 2 van 2
    • Remove the three ribbon cables for the screen and battery
    • Remove the speaker cover this will show the ribbon cable you will remove which is connected to the screen
  4. Samsung Galaxy A22/A22 5G Screen Replacement, Place new screen: stap 4, afbeelding 1 van 1
    • Next remove your old screen with a iOpener or a heat gun and a pry cart go all round the edges to take of the old display
    • make sure you go all around the edges clean left out adhesive and make sure the front is properly clean
    • Place the ribbon cable inside the gap of the frame and assemble it
    • Place your new adhesive around the frame of the phone place your new screen on top of the frame
  5. Samsung Galaxy A22/A22 5G Screen Replacement, add adhesive and put the phone back together: stap 5, afbeelding 1 van 1
    • closed it up and use Clamp holders to press around the whole screen of the phone make sure it sticks in place
    • Then turn the phone around place the all the ribbon cables back in place make sure your new screen works
    • close the back cover with new adhesive use clamp Holders to help you completely seal it up
    • If you don't have clamp holders you can use ruber bands
Conclusie
13 andere personen hebben deze handleiding voltooid.
Ellusion
1.684 Reputatie
5 handleidingen geschreven
5 opmerkingen
Thanks for the help
Angelos Vasileiou - Antwoord
It is not Galaxy A22 5G device on the pics.
Jeffrey Kim - Antwoord
Samsung à 22
Baleme -
Adhesive missing in “Needed parts”
Max Brandenburger - Antwoord
Which adhesive do you recommend to replace these screens
Paul - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 24
Afgelopen 7 dagen: 151
Afgelopen 30 dagen: 549
Altijd: 11,432
