Inleiding
This guide will show you how to disassemble the Samsung Galaxy S so that you can gain access to the speaker.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
To remove the back case of the Samsung Galaxy S, you may need a spudger.
Identify the slit which is at the bottom edge of the phone.
Insert the spudger into the space between the battery and the phone and pry the battery out as you slide it along the underside the battery.
Use the screwdriver to unscrew each of the 6 silver screws holding the main case to the LCD touchscreen.
If the screws are stuck, use the spudger to pry them out.
