Ga door naar hoofdinhoud
Samsung Exhibit II 4G Rear Facing Camera Replacement
Wat je nodig hebt
  1. Samsung Exhibit II 4G Rear Facing Camera Replacement, Battery: stap 1, afbeelding 1 van 1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Rear Facing Camera Replacement: stap 2, afbeelding 1 van 1
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Rear Facing Camera Replacement, Top Rear Housing Cover: stap 3, afbeelding 1 van 1
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Rear Facing Camera Replacement: stap 4, afbeelding 1 van 1
    • Remove the top cover.
  5. Samsung Exhibit II 4G Rear Facing Camera Replacement: stap 5, afbeelding 1 van 2 Samsung Exhibit II 4G Rear Facing Camera Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Rear Facing Camera Replacement: stap 6, afbeelding 1 van 3 Samsung Exhibit II 4G Rear Facing Camera Replacement: stap 6, afbeelding 2 van 3 Samsung Exhibit II 4G Rear Facing Camera Replacement: stap 6, afbeelding 3 van 3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Rear Facing Camera Replacement, Midframe: stap 7, afbeelding 1 van 1
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Rear Facing Camera Replacement: stap 8, afbeelding 1 van 1
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Rear Facing Camera Replacement: stap 9, afbeelding 1 van 1
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Rear Facing Camera Replacement: stap 10, afbeelding 1 van 1
    • Pull back panel assembly away from main body.
  11. Samsung Exhibit II 4G Rear Facing Camera Replacement, Rear Facing Camera: stap 11, afbeelding 1 van 1
    • Use the flat end of a spudger to disconnect the camera assembly cable.
  12. Samsung Exhibit II 4G Rear Facing Camera Replacement: stap 12, afbeelding 1 van 2 Samsung Exhibit II 4G Rear Facing Camera Replacement: stap 12, afbeelding 2 van 2
    • Remove camera from square housing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
David R
1.152 Reputatie
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 195
