Ga door naar hoofdinhoud
Samsung Exhibit II 4G Loudspeaker Replacement
Wat je nodig hebt
  1. Samsung Exhibit II 4G Loudspeaker Replacement, Battery: stap 1, afbeelding 1 van 1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
    Vraag FixBot
  2. Samsung Exhibit II 4G Loudspeaker Replacement: stap 2, afbeelding 1 van 1
    • Insert plastic opening tool under battery.
    • Pry battery out.
    Vraag FixBot
  3. Samsung Exhibit II 4G Loudspeaker Replacement, Top Rear Housing Cover: stap 3, afbeelding 1 van 1
    • Pry the top cover upward to remove it from the phone.
    Vraag FixBot
  4. Samsung Exhibit II 4G Loudspeaker Replacement: stap 4, afbeelding 1 van 1
    • Remove the top cover.
    Vraag FixBot
  5. Samsung Exhibit II 4G Loudspeaker Replacement: stap 5, afbeelding 1 van 2 Samsung Exhibit II 4G Loudspeaker Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
    Vraag FixBot
  6. Samsung Exhibit II 4G Loudspeaker Replacement: stap 6, afbeelding 1 van 3 Samsung Exhibit II 4G Loudspeaker Replacement: stap 6, afbeelding 2 van 3 Samsung Exhibit II 4G Loudspeaker Replacement: stap 6, afbeelding 3 van 3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
    Vraag FixBot
  7. Samsung Exhibit II 4G Loudspeaker Replacement, Midframe: stap 7, afbeelding 1 van 1
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
    Vraag FixBot
  8. Samsung Exhibit II 4G Loudspeaker Replacement: stap 8, afbeelding 1 van 1
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
    Vraag FixBot
  9. Samsung Exhibit II 4G Loudspeaker Replacement: stap 9, afbeelding 1 van 1
    • With plastic opening tool continue prying around the edge of the back assembly.
    Vraag FixBot
  10. Samsung Exhibit II 4G Loudspeaker Replacement: stap 10, afbeelding 1 van 1
    • Pull back panel assembly away from main body.
    Vraag FixBot
  11. Samsung Exhibit II 4G Loudspeaker Replacement, Loudspeaker: stap 11, afbeelding 1 van 3 Samsung Exhibit II 4G Loudspeaker Replacement, Loudspeaker: stap 11, afbeelding 2 van 3 Samsung Exhibit II 4G Loudspeaker Replacement, Loudspeaker: stap 11, afbeelding 3 van 3
    • Position Back Panel Assembly so the internal Loudspeaker unit is facing up.
    • With your index fingers and thumbs, grasp the Back Panel Assembly near the Loudspeaker.
    • Twist your palms inward to apply pressure against your index fingers.
    • The Loudspeaker will easily pop out.
    Vraag FixBot
Conclusie
Één andere persoon heeft deze handleiding voltooid.
David R
1.152 Reputatie
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 40
Altijd: 517
