Ga door naar hoofdinhoud
Samsung Exhibit II 4G Headphone Jack Replacement
Wat je nodig hebt
  1. Samsung Exhibit II 4G Headphone Jack Replacement, Battery: stap 1, afbeelding 1 van 1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Headphone Jack Replacement, Top Rear Housing Cover: stap 3, afbeelding 1 van 1
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Headphone Jack Replacement: stap 4, afbeelding 1 van 1
    • Remove the top cover.
  5. Samsung Exhibit II 4G Headphone Jack Replacement: stap 5, afbeelding 1 van 2 Samsung Exhibit II 4G Headphone Jack Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Headphone Jack Replacement: stap 6, afbeelding 1 van 3 Samsung Exhibit II 4G Headphone Jack Replacement: stap 6, afbeelding 2 van 3 Samsung Exhibit II 4G Headphone Jack Replacement: stap 6, afbeelding 3 van 3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Headphone Jack Replacement, Midframe: stap 7, afbeelding 1 van 1
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Headphone Jack Replacement: stap 8, afbeelding 1 van 1
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Headphone Jack Replacement: stap 9, afbeelding 1 van 1
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Headphone Jack Replacement: stap 10, afbeelding 1 van 1
    • Pull back panel assembly away from main body.
  11. Samsung Exhibit II 4G Headphone Jack Replacement, Vibration Motor: stap 11, afbeelding 1 van 2 Samsung Exhibit II 4G Headphone Jack Replacement, Vibration Motor: stap 11, afbeelding 2 van 2
    • Insert the pointed end of a spudger into the gap in the round housing frame.
    • Using spudger to remove vibrator remove from the adhesive.
  12. Samsung Exhibit II 4G Headphone Jack Replacement: stap 12, afbeelding 1 van 2 Samsung Exhibit II 4G Headphone Jack Replacement: stap 12, afbeelding 2 van 2
    • Use the flat end of a spudger to remove vibrator cable from motherboard.
  13. Samsung Exhibit II 4G Headphone Jack Replacement, Rear Facing Camera: stap 13, afbeelding 1 van 1
    • Use the flat end of a spudger to disconnect the camera assembly cable.
  14. Samsung Exhibit II 4G Headphone Jack Replacement: stap 14, afbeelding 1 van 2 Samsung Exhibit II 4G Headphone Jack Replacement: stap 14, afbeelding 2 van 2
    • Remove camera from square housing.
  15. Samsung Exhibit II 4G Headphone Jack Replacement, Motherboard: stap 15, afbeelding 1 van 3 Samsung Exhibit II 4G Headphone Jack Replacement, Motherboard: stap 15, afbeelding 2 van 3 Samsung Exhibit II 4G Headphone Jack Replacement, Motherboard: stap 15, afbeelding 3 van 3
    • Insert the spudger under each corner ribbon cable and lift them out of the way.
    • Use care when lifting the ribbon cables.
    • Insert a plastic pry tool into the gap between motherboard and base of phone
  16. Samsung Exhibit II 4G Headphone Jack Replacement: stap 16, afbeelding 1 van 3 Samsung Exhibit II 4G Headphone Jack Replacement: stap 16, afbeelding 2 van 3 Samsung Exhibit II 4G Headphone Jack Replacement: stap 16, afbeelding 3 van 3
    • Tilt the motherboard up carefully.
    • Be sure not to damage the ribbon cable still connected at the bottom of the motherboard.
    • Use a spudger to pry the connector from the socket on the motherboard.
    • Lift motherboard from frame.
  17. Samsung Exhibit II 4G Headphone Jack Replacement, Headphone Jack: stap 17, afbeelding 1 van 3 Samsung Exhibit II 4G Headphone Jack Replacement, Headphone Jack: stap 17, afbeelding 2 van 3 Samsung Exhibit II 4G Headphone Jack Replacement, Headphone Jack: stap 17, afbeelding 3 van 3
    • Insert flat end of spudger between support panel and front assembly.
    • Using a spudger pry up to create opening to insert plastic opening tool.
  18. Samsung Exhibit II 4G Headphone Jack Replacement: stap 18, afbeelding 1 van 2 Samsung Exhibit II 4G Headphone Jack Replacement: stap 18, afbeelding 2 van 2
    • Insert a plactic opening tool in opening.
    • Use plastic opening tool to pry around the edge of support panel to free it from front assembly.
  19. Samsung Exhibit II 4G Headphone Jack Replacement: stap 19, afbeelding 1 van 3 Samsung Exhibit II 4G Headphone Jack Replacement: stap 19, afbeelding 2 van 3 Samsung Exhibit II 4G Headphone Jack Replacement: stap 19, afbeelding 3 van 3
    • Insert the pointed end of a spudger into gap.
    • Lift spudger away from support plate to remove headphone component.
  20. Samsung Exhibit II 4G Headphone Jack Replacement: stap 20, afbeelding 1 van 3 Samsung Exhibit II 4G Headphone Jack Replacement: stap 20, afbeelding 2 van 3 Samsung Exhibit II 4G Headphone Jack Replacement: stap 20, afbeelding 3 van 3
    • Use the flat end of the spudger to remove headphone jack component from rectangular housing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
David R
1.152 Reputatie
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 278
