Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using the Phillips #00 screwdriver, remove the phone's battery.
Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver
Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
Pop the red hinged-release lever away from its ribbon. Then pull it out.
Peel the button sensor on the side of the motherboard off of the case.
Slightly pull up one side of the motherboard.
Pull the button/microphone plug out of its socket.
Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
You have successfully removed the motherboard from the phone.
