Ga door naar hoofdinhoud
Samsung Eternity Microphone Replacement
Wat je nodig hebt
    • Remove the back battery cover.
  1. Samsung Eternity Microphone Replacement: stap 2, afbeelding 1 van 1
    • Using a nylon spudger, remove the phone's battery.
  2. Samsung Eternity Microphone Replacement: stap 3, afbeelding 1 van 1
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
  3. Samsung Eternity Microphone Replacement: stap 4, afbeelding 1 van 2 Samsung Eternity Microphone Replacement: stap 4, afbeelding 2 van 2
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Microphone Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
  5. Samsung Eternity Microphone Replacement: stap 6, afbeelding 1 van 3 Samsung Eternity Microphone Replacement: stap 6, afbeelding 2 van 3 Samsung Eternity Microphone Replacement: stap 6, afbeelding 3 van 3
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
  6. Samsung Eternity Microphone Replacement: stap 7, afbeelding 1 van 1
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
  7. Samsung Eternity Microphone Replacement: stap 8, afbeelding 1 van 1
    • Peel the button sensor on the side of the motherboard off of the case.
  8. Samsung Eternity Microphone Replacement: stap 9, afbeelding 1 van 3 Samsung Eternity Microphone Replacement: stap 9, afbeelding 2 van 3 Samsung Eternity Microphone Replacement: stap 9, afbeelding 3 van 3
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  9. Samsung Eternity Microphone Replacement: stap 10, afbeelding 1 van 1
    • You have successfully removed the motherboard from the phone.
  10. Samsung Eternity Microphone Replacement, Digitizer and Screen: stap 11, afbeelding 1 van 1
    • Flip the phone over so you are looking at the front screen of the phone.
  11. Samsung Eternity Microphone Replacement: stap 12, afbeelding 1 van 3 Samsung Eternity Microphone Replacement: stap 12, afbeelding 2 van 3 Samsung Eternity Microphone Replacement: stap 12, afbeelding 3 van 3
    • Use a small tool to pry the digitizer and screen (together) from the frame of the phone.
    • This may take some time and careful work because it is glued down to the frame.
    • Be careful when you pull the lower part of this piece away from the phone frame because there is a ribbon attached to the digitizer that you don't want to break. There is also a ribbon on the side of the screen to be aware of.
  12. Samsung Eternity Microphone Replacement: stap 13, afbeelding 1 van 3 Samsung Eternity Microphone Replacement: stap 13, afbeelding 2 van 3 Samsung Eternity Microphone Replacement: stap 13, afbeelding 3 van 3
    • Next, carefully pull the digitizer away from the screen.
    • At this point you can replace either the screen or the digitizer.
    • Cleaning the screen with a glass cleaning cloth before reassembling will remove any smudges or fingerprints from disassembling the device.
  13. Samsung Eternity Microphone Replacement, Microphone: stap 14, afbeelding 1 van 1
    • Pop the microphone up and out of its small housing.
  14. Samsung Eternity Microphone Replacement: stap 15, afbeelding 1 van 1
    • Peel up the black tape on the bottom of the back case.
  15. Samsung Eternity Microphone Replacement: stap 16, afbeelding 1 van 1
    • Use the spudger to release the front buttons from the phones frame.
    • Don't try and pull the front buttons completely away from the phone. There are clips that still are holding them to the phone.
  16. Samsung Eternity Microphone Replacement: stap 17, afbeelding 1 van 3 Samsung Eternity Microphone Replacement: stap 17, afbeelding 2 van 3 Samsung Eternity Microphone Replacement: stap 17, afbeelding 3 van 3
    • Use the spudger to remove three plastic lasso hooks that are holding the front buttons to the case.
    • The front button plastic assembly should come right off.
  17. Samsung Eternity Microphone Replacement: stap 18, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use tweezers to release the button logic board away from the phone's casing.
    • Do not try and completely remove the component. There are logic ribbons that need to be guided through the phone's back casing.
  18. Samsung Eternity Microphone Replacement: stap 19, afbeelding 1 van 1
    • You should be able to see two cables connected to the front button board.
    • Carefully slide these two cables through their respective holes in the body of the camera.
  19. Samsung Eternity Microphone Replacement: stap 20, afbeelding 1 van 1
    • The front button board should slide out. At this time you can replace the button/microphone component.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Michelle Haddock
51 Reputatie
3 handleidingen geschreven
Cal Poly, Team 15-11, Regan Spring 2011 Lid van Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 46
Altijd: 2,430
