Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using the Phillips #00 screwdriver, remove the phone's battery.
Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver
Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
Pop the antenna plug off of its socket with a pair of metal tweezers.
Peel the button sensor on the side of the motherboard off of the case.
Pry the antennae/speaker component out of its casing. You need to use a little force to get the piece to pop out.
You will now be able to replace the antenna/speaker module.
