Ga door naar hoofdinhoud
Samsung Epix LCD Display Replacement
Wat je nodig hebt
  1. Samsung Epix LCD Display Replacement, Battery: stap 1, afbeelding 1 van 1
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
  2. Samsung Epix LCD Display Replacement: stap 2, afbeelding 1 van 1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
  3. Samsung Epix LCD Display Replacement, LCD Display: stap 3, afbeelding 1 van 1
    • Remove the rubber screw cover in the top left corner by prying upwards with an opening tool.
  4. Samsung Epix LCD Display Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • The upper right screw is 4.5 mm and the others are 6.5 mm.
  5. Samsung Epix LCD Display Replacement: stap 5, afbeelding 1 van 2 Samsung Epix LCD Display Replacement: stap 5, afbeelding 2 van 2
    • Slide the opening tool along the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix LCD Display Replacement: stap 6, afbeelding 1 van 1
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It will still be connected to the phone chassis by a ribbon cable on the motherboard.
  7. Samsung Epix LCD Display Replacement: stap 7, afbeelding 1 van 1
    • Using an opening tool, undo the ZIF connector halfway up the right side.
    • Carefully remove ribbon cable.
  8. Samsung Epix LCD Display Replacement: stap 8, afbeelding 1 van 1
    • Remove the front faceplate by lifting it off of the phone chassis.
  9. Samsung Epix LCD Display Replacement: stap 9, afbeelding 1 van 1
    • Using the opening tool, unlatch the LCD ribbon cable.
  10. Samsung Epix LCD Display Replacement: stap 10, afbeelding 1 van 1
    • Using an opening tool or spudger, pry under the lower left and right corners of the LCD screen.
    • The LCD is held in place to the chassis with adhesive strips.
    • Do not pry excessively hard. You may damage the circuitry on the back of the LCD.
  11. Samsung Epix LCD Display Replacement: stap 11, afbeelding 1 van 1
    • Lift the LCD display out from phone chassis.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mark Wyse
62 Reputatie
2 handleidingen geschreven
Cal Poly, Team 15-15, Regan Spring 2011 Lid van Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 2,003
