Ga door naar hoofdinhoud
Samsung Epic 4G Touch microSD Card Replacement
Wat je nodig hebt
  1. Samsung Epic 4G Touch microSD Card Replacement, Rear Case: stap 1, afbeelding 1 van 2 Samsung Epic 4G Touch microSD Card Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch microSD Card Replacement: stap 2, afbeelding 1 van 2 Samsung Epic 4G Touch microSD Card Replacement: stap 2, afbeelding 2 van 2
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch microSD Card Replacement, microSD Card: stap 3, afbeelding 1 van 2 Samsung Epic 4G Touch microSD Card Replacement, microSD Card: stap 3, afbeelding 2 van 2
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • During reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Epic 4G Touch microSD Card Replacement: stap 4, afbeelding 1 van 1
    • Pull the microSD card away from its slot.
Conclusie
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Uhh.... my Australian SGSII looks different to this...
Bonj - Antwoord
If you are having trouble addint a 64gb micro sd card, it's because you have to first format that card to FAT32. You have to do that to the memory card through a computer. Youtube too, it'll help
asff - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 11
Altijd: 4,366
