Ga door naar hoofdinhoud
Samsung Epic 4G Touch Battery Replacement
Wat je nodig hebt
  1. Samsung Epic 4G Touch Battery Replacement, Rear Case: stap 1, afbeelding 1 van 2 Samsung Epic 4G Touch Battery Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch Battery Replacement: stap 2, afbeelding 1 van 2 Samsung Epic 4G Touch Battery Replacement: stap 2, afbeelding 2 van 2
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch Battery Replacement, Battery: stap 3, afbeelding 1 van 2 Samsung Epic 4G Touch Battery Replacement, Battery: stap 3, afbeelding 2 van 2
    • Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
    • Push the plastic opening tool downward to pry the battery up from its housing.
  4. Samsung Epic 4G Touch Battery Replacement: stap 4, afbeelding 1 van 2 Samsung Epic 4G Touch Battery Replacement: stap 4, afbeelding 2 van 2
    • Lift and remove the battery from the midframe.
Conclusie
10 andere personen hebben deze handleiding voltooid.
2 opmerkingen
i just reacently got my phone and I don't know whats happening to it. it keeps turning itself off. iv factory reset it 2 times. should I replace the phone or just the battery. I have a Samsung galaxy s II. (sprint)
gamerzzz - Antwoord
I have an samsung galaxy s2 gsm unlocked and my battery wont stay charge and sometimes when its plugged in a charger it decreases instead of increasing and if it does charges it decrease fast what shall i do shall i get a new battery or replace the phone
ianasims - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 9,700
