Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Samsung Epic 4G Power Button Replacement
Wat je nodig hebt
  1. Samsung Epic 4G Power Button Replacement, Phone Case: stap 1, afbeelding 1 van 1
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. Samsung Epic 4G Power Button Replacement: stap 2, afbeelding 1 van 1
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
  3. Samsung Epic 4G Power Button Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove the battery from the device by pulling the battery edge upwards.
  4. Samsung Epic 4G Power Button Replacement, Removing the Memory Card:: stap 4, afbeelding 1 van 1
    • Remove the memory card from the device by gently sliding it out of its holder.
  5. Samsung Epic 4G Power Button Replacement, Removing the Back Housing: stap 5, afbeelding 1 van 2 Samsung Epic 4G Power Button Replacement, Removing the Back Housing: stap 5, afbeelding 2 van 2
    • Remove the seven screws from the back of the phone using the Phillips screwdriver.
    • Separate the back housing from the silver trim around the phone using a nylon spudger.
    • While separating the two pieces, most of the buttons (including the power button) will fall out.
  6. Samsung Epic 4G Power Button Replacement, Removing the Power Button: stap 6, afbeelding 1 van 2 Samsung Epic 4G Power Button Replacement, Removing the Power Button: stap 6, afbeelding 2 van 2
    • If it did not fall out in the previous step, remove the power button using tweezers.
    • At this point, you can replace the button with a new one.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Andrew Cunningham
273 Reputatie
6 handleidingen geschreven
Cal Poly, Team 24-25, Regan Fall 2012 Lid van Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,270
