Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide details how to install a new power button into your Samsung Epic 4G. Directions are provided for both disassembly and reassembly.
Wat je nodig hebt
Slide your fingernail along the edge of the device and pull at the plastic backing.
Remove the memory card from the device by gently sliding it out of its holder.
Remove the seven screws from the back of the phone using the Phillips screwdriver.
Separate the back housing from the silver trim around the phone using a nylon spudger.
If it did not fall out in the previous step, remove the power button using tweezers.
Één andere persoon heeft deze handleiding voltooid.
